查看: 13|回复: 0
TIG to MIG conversion
发表于 2021-8-31 23:25:50 | 显示全部楼层 |阅读模式
I recently purchased a 200A pulsed inverter based TIG welder (DC only) for a decent price.  The unit can be set to stick welding and also 2T or 4T TIG (unfortunately without foot pedal). Questions:Would it be feasible to mount a MIG style spool gun (or another wire feed unit) for Alu welding to this machine? (Assuming I can obtain the correct voltage / current to drive the gun rollers - perhaps from an external source). Will the DC current work well for MIG? Pulsing is however only between 0.5 and 25 Hz (slow). Cheers!
Reply:Not really. Your machine is Constant Current. To do mig you really need a Constant Voltage powersource..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:You need to look at spoolguns or suitcase wirefeeders that are made to work with a CC power source.  They can be expensive, but they are your only option.Have we all gone mad?
GMT+8, 2025-12-27 01:39 , Processed in 0.110174 second(s), 18 queries .
