Need Help Sourcing A Brass Finial
发表于 2021-8-31 23:25:46 | 显示全部楼层 |阅读模式
I am looking for two of these pineapple shaped brass finials for a handrail I am building.  I am stumped, called King, Triple S, Texas Metals, and a couple others I can't remember off hand.  I would prefer them to be about 2 1/2" tall but could be a little bigger.  Any ideas? Thanks Attached Imageswww.somethingdifferentftw.blogspot.com
Reply:King has pineapple finials, just in cast steel, not brass.  Why don't you get them in steel, and paint them in gold?http://www.kingmetals.com/Catalog/It...C48CA703E39AF4
Reply:try Jansen, Blumand Google--has a bunch you'll need to sort thruBlackbird
Reply:Thanks for the lead on Jansen, I've tried Blum.  No luck either place.  I can't paint cast it's a very high end client. Google has just been a frustration.  Thank you both.  I just thought maybe there was a brass supplier I was unaware of.www.somethingdifferentftw.blogspot.com
Reply:could ya  get cast and have em plated or bronzed 350P 30A spool gun cut master 51  syncro 250 other stuff " take a dog off the street and make him prosper and he will not bite you sad the same cannot be said for man" i didnt use punctuation just to piss you off
Reply:My powder coater matches brass pretty good and it never has to be polished.
Reply:Buy the steel ones and use them to make a mold and have them cast in bronze or brass.Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:Do you have the one in the photo? There is a foundry in Richmond VA that specializes in small run castings, they do a lot of reproductions for restoring cast iron and bronze. There may be someone near you that does this. I can look up the guys in Richmond if you want...Sent from my Kindle Fire using TapatalkMiller Maxstar 200 DX - Syncrowave 200 - MillerMatic 200 - Bobcat 225 NT - Spoolmate 3035/SGA 1003 X Lincoln Power MIGs (200, 215XT 255)3 X Lincoln SP's (100, 125, 130)Thermal Arc 181i (spool gun and TIG torch)HT Powermax 1000 G3
Reply:Try Whitechapelhttp://www.whitechapel-ltd.com/category/fin.html-DaveXMT304 with: 22A Feeder, or HF251 Hi Freq DC TIG air cooled
Reply:Thanks to all for suggestions. I just found this place, I ordered two, they have 18 left if anyone needs them http://www.architecturalclearancecen...le-Finial.html.  They are just over 2" tallwww.somethingdifferentftw.blogspot.com
GMT+8, 2025-12-27 01:39 , Processed in 0.078782 second(s), 18 queries .
