weldcraft 22ft cable cover price
发表于 2021-8-31 23:25:40 | 显示全部楼层 |阅读模式
Does anyone  know of a place   that sells  the   weldcraft 22ft cable  cover   for less then $70.00   ?      or  a good compareable  one ..        found this one on  ebay  > > WeldCraft 366-WC-3-22 3 Inchx22' Cable CoverAlways Save with UnbeatableSale​!Location: New Jersey Watch this item  Buy It Now $70.52Free shipping Time left:9d 23h 20m>Innovations are what i leave behind for History
Reply:Got a 22' Radnor one from Airgas the other day.  $63 and change out the door and in my hand.
Reply:Went to REI sporting goods and bought 2" tubular nylon webbing. Fished a string through and pulled my cables back through. Cost was around $13 for a 23 ft length.
Reply:Jay O, can you post a picture of your set up? It sounds interesting.Ian TannerKawasaki KX450 and many other fine tools
Reply:yea im curious  to  ,  pics would be   great , and a place to buy it  ..  thats like 1/4   the price  of  a weldcraft>Innovations are what i leave behind for History
Reply:cyberweld (pn.wc-3-22) are $103.02id like to get one for my 30A spool gun
Reply:Heres what i used as a cover on my 2 piece tig torch that i use for scratch start. I think it only costed me around 12.00. Its a expandable cable mesh that worked great. Heres where i got it from,http://www.cabletiesandmore.com/ExpandableSleeving.phpYa gotta spend money to make money!
Reply:Originally Posted by Jay OWent to REI sporting goods and bought 2" tubular nylon webbing. Fished a string through and pulled my cables back through. Cost was around $13 for a 23 ft length.
Reply:Here are some pictures. As you see I have an aircooled torch but this should work for a water cooled torch also. Attached Images
Reply:I've seen the tubing used for protecting tow ropes and strops used. At a fraction of the cost of so called  "TIG covers"
Reply:WelderShane what size did you order for your use?
Reply:Thanks for the info!Ian TannerKawasaki KX450 and many other fine tools
GMT+8, 2025-12-27 03:30 , Processed in 0.094461 second(s), 18 queries .
