Here is a project that I have underway. It's based off of Terry Taske's design and Blind Chicken Racing. I drew up my plans in Autocad and sent the dxf file of the revised design to a local laser cutter. I ordered the parts from Pro Tools in Florida. I still have some work to do before it's operational but I'm pretty close. The second photo is what I did to make sure everything was square lengthwise from top to bottom. The small holes on the side are locator holes that I had cut so that the inside pieces with tabs snapped together. It went together like a Lego set. Miller Dynasty 200DXLincoln SP175Grizzly 14" Band SawRigid CM1450 Chop SawJD2 TN-100 Tube Notcher
Reply:Here are a couple more shots of it. My welds are nothing like the good folks on this forum but I do OK for a wally weekender. The parts from Pro Tools need to be reworked a bit but at least I have a great start with their kit.Miller Dynasty 200DXLincoln SP175Grizzly 14" Band SawRigid CM1450 Chop SawJD2 TN-100 Tube Notcher
Reply:Looks like an excellent job so far! It's probably because I'm unfamiliar with that style bender, but the frame appears light for the job. Hopefully, I'm utterly and completely wrong, due to my design ignorance, and you get years of service from that build.Lincoln PrecisionTig 275Miller 251Miller DialArc 250Bridgeport millHossfeld bender & diesLogan shaperJet 14 X 40 latheSouth Bend 9" 'C'Hypertherm 900Ellis 3000 band saw21"Royersford ExcelsiorTwo shops, still too many tools.
Reply:I like the simplicity of your design.Please post a video when in use.Lincoln SA 200Esab Caddy 160Thermal Arc 201TSMiller Dialarc HFI don't like making plans for the day because then the word "premeditated" gets thrown around the courtroom.... |
