Quick reference chart for aluminum.
发表于 2021-8-31 23:25:35 | 显示全部楼层 |阅读模式
Ok my second newbe question,Is there a single rescore that can tell you what alloys you can weld and which ones you can’t? I know there are some that you can’t and some that you can’t even bend without breaking. It would be nice to have a quick reference chart in the way of a poster or something like that.  Do you all know where I might resource something like that? Thanks, Dave.
Reply:http://www.alcotec.com/us/en/support...tion_Chart.pdfhttp://www.alcotec.com/us/en/educati...e/qa/index.cfmTake a look through their websiteEd Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:As a start, I would say that if an alloy isn't on a filler selection chart, it's either not weldable or would require some extra research. I would also add that even though an alloy is on the chart, it doesn't mean that it would be an easy go. Hope that helps a bit. http://www.alcotec.com/us/en/support...tion-Chart.pdfEdit: oops. Ed beat me to it.
Reply:Simple version: If the alloy number begins with a 2 or a 7, you can't weld it, with very few exceptions. Most other aluminum alloys are weldable; those charts will tell you which filler to use.JohnA few weldersA lot of hammersA whole lot of C-clamps
Reply:You guys are the bomb..............................................
GMT+8, 2025-12-27 03:28 , Processed in 0.092358 second(s), 18 queries .
