Rod choices
发表于 2021-8-31 23:25:34 | 显示全部楼层 |阅读模式
I need to know what type of rod to use to weld axle spindles to steel tube axle material.  ( yup..... another noob question  )Thanks in advance for your help
Reply:I assume it will slip fit in the tubbing ?   I would use 7018 or 8018 your question raises some concern as to your skill for such critical weld no of fence intended just saying
Reply:Popcorn...check beer...check fire extingusher...check. Ok let the flaming beginMillermatic 252millermatic 175miller 300 Thunderboltlincoln ranger 250smith torcheslots of bfh'sIf it dont fit get a bigger hammer
Reply:Originally Posted by skylineI assume it will slip fit in the tubbing ?   I would use 7018 or 8018 your question raises some concern as to your skill for such critical weld no of fence intended just saying
Reply:Originally Posted by farmshopPopcorn...check beer...check fire extingusher...check. Ok let the flaming begin
GMT+8, 2025-12-27 03:28 , Processed in 0.092999 second(s), 18 queries .
