Can someone help me with my Miller Tig?
发表于 2021-8-31 23:25:33 | 显示全部楼层 |阅读模式
I have come across an OLD Miller Maxstar 150 with a Miller 251D-1 High Frequency Box. I have set up everything according to the instructions and have gas regulated at 15. I am using a 3/32 Tungsten Rod. It seems that I have no control with my foot pedal, the welds are VERY Hot no matter what how low I set the amperage.. I got this unit at a good price. All the TIG welding that I have done was with a new unit than this.
Reply:I don't know anything about that machine. There is Amperage control switch on the welder, have you tried it set to remote? Also try setting the HF-251 to remote. There is only a few things to change on that machine so a little trial and error should find the results you want. Others that use separate HF units will probably be able to help more.Airco Ac/Dc 300 HeliwelderMillerMatic 200 (stolen)Miller Maxstar 150STLMiller AEAD200LE (welding and generating power) Hobart MIG
Reply:You will need a control cable, pin conectors, to connect the welder out put to the HF box. I think the HF box takes 9 pins, my newer max star is a 6 pin, I think. The foot pedal is connected to the HF box. All switches are to be set on remote.Miller TrailBlazer 251Miller HF-250-1Miller MaxStar 150 STLHyperTherm PowerMax 380 plasmaLincoln PowerMig 180Millermatic 252Miller Diversion 180
Reply:Your HF251 uses a 14 pin cable to connect to your welder, then your pedal plugs into the 251. In addition, as said above, both machines should be set to REMOTE for amp control and contactor control.  If the Maxstar has a 6 pin input, you'll either need an adapter to connect to the HF251 or you'll have to keep the pedal plugged into the Maxstar then manually turn the HF box on to continuous when you weld.  It's a noisy little machine.  It's designed to be used the way I stated above.  The pedal triggers the HF box and also the welder, but it needs to go through the HF box.Last edited by Drf255; 12-05-2013 at 05:20 AM.TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
GMT+8, 2025-12-27 03:30 , Processed in 0.098855 second(s), 18 queries .
