Inert Gas Regulator
发表于 2021-8-31 23:25:29 | 显示全部楼层 |阅读模式
Will regulators labeled for use with Inert Gas handle pure Argon, pure CO2 and 75/25?
Reply:The scale on the flowmeter side is a little different for the different gasses, but they will work fine.6 Miller Big Blue 600 Air Paks2 Miller 400D6 Lincoln LN-25's4 Miller Xtreme 12VS2 Miller Dimension 812 4 Climax BW-3000Z bore welders Hypertherm 65 and 85Bug-O Track BugPair of Welpers
Reply:That's not exactly correct.First thing that needs to be clarified is whether the OP is talking about a "Regulator" or a "Flowmeter Regulator".  A "regulator" simply steps the gas pressure down from the high pressure in the bottle to a usable level (generally between 5 and 100 lbs).A flowmeter regulator steps the high pressure down to a usable level (generally about 50 PSI) and then provides for adjustment to the flow rate.Regulators are used on ox/ace equipment as well as on the gas mixers.  Regulator flowmeters are generally used on mig, tig, etc.Inert gases and C25 use a CGA580 connection on the bottle/regulator.CO2 uses a CGA320 connection on the bottle/regulator.OP needs to clarify what he's talking about.Syncro 250 DX Dynasty 200 DXMM 251 w/30A SG XMT 304 w/714 Feeder & Optima PulserHH187Dialarc 250 AC/DCHypertherm PM 1250Smith, Harris, Victor O/ASmith and Thermco Gas MixersAccess to a full fab shop with CNC Plasma, Water Jet, etc.
Reply:I am talking about a regulator flowmeter.  I am looking for one to use on a TIG rig with pure argon.  The regulators I see on Cyberweld, etc. simply say Inert Gas.  I am wanting to be sure these flowmeters will work with pure argon.
Reply:Isn't argon still an inert gas? For guaranteed compatibility with your equipment, you can email or call Cyberweld. Their customer service is excellent.
GMT+8, 2025-12-27 03:28 , Processed in 0.094246 second(s), 18 queries .
