Sorry, its a table
发表于 2021-8-31 23:25:27 | 显示全部楼层 |阅读模式
42" by 6' made of 4 x 13 I beam. Set on 1300lb swivel casters. I haven't secured the beam sections to the top yet, the spacing will be 2 inches. Attached ImagesMillermatic® 252 w/ Spoolmatic® 30AHypertherm Powermax65Jet 5" x 6" Horizontal / Vertical Bandsaw DEWALT 14in. Abrasive Chop SawThemal Gel so the welding doesn't melt my Igloo
Reply:What's she for? Pretty rugged.....
Reply:how flat is that cause i beam tends to have twistsMiller Xmt 350Lincoln Ln-25Ahp 200xSmith Gas Mixer AR/HTig is my Kung FuThrowing down dimes and weaving aboutInstagram http://instagram.com/[email protected]
Reply:Originally Posted by astaindsoul5446What's she for? Pretty rugged.....
Reply:Originally Posted by chimmikejust what I was thinking, on 1300# casters!
Reply:Yeah, I think it's safe to say you could slam on it with a 15lb sledge and not dent it....Hobart EZ-Tig newbie.
Reply:Dude, yOu could park you truck on that thing.....
Reply:how long did cutting those beams take per cut?  Did you have to flip it to get all the way through it?miller syncrowave 250hobart handler 140home made 400 amp engine driven in progress...
Reply:Originally Posted by jdchmielhow long did cutting those beams take per cut?  Did you have to flip it to get all the way through it?
Reply:i beam tends to have twists
Reply:Its probably fine but I would slap some 1/8 plate on the 4 "corners" to box in the beam where the legs are. Just looks funny either that or maybe weld some tube in at the bottom to keep the legs from wanting to do a split.
Reply:Originally Posted by AKwatermanI used what is called a rescue blade. It is a diamond coated abrasive blade that fire departments use in their rescue saws. It took about 3 minutes a cut and I didn't have to flip it at all. I choose to cut it with 2 verticals and 1 flat thinking it would be fastest.18 cuts in all and the blade still looks untouched.
Reply:Originally Posted by DeloresWhittieri beam tends to have twists
Reply:Here it is mostly finished. just need to mount some attachments Attached ImagesMillermatic® 252 w/ Spoolmatic® 30AHypertherm Powermax65Jet 5" x 6" Horizontal / Vertical Bandsaw DEWALT 14in. Abrasive Chop SawThemal Gel so the welding doesn't melt my Igloo
Reply:With all that material you should have built a "heavy duty" table.  JK. Looks good.
Reply:I like the built in storage shelf for the grinder, etc. Looks like a neat design.
Reply:Originally Posted by AKwaterman42" by 6' made of 4 x 13 I beam...
Reply:I'm curious how you like it after using it a bit. Looks very nice.
Reply:Originally Posted by MondoI - beam?   Or is that wide flange or H column?I beams have a sloped flange that are difficult to clamp to.  Most common clamps (C-clamps and such)  tend to loosen and slide off.  Wide flange or H column have a flange with parallel surfaces which are easy to clamp to.- Mondo
Reply:great way to use up smaller beam leftovers - I like it!Thermal Arc Fabricator 2101970 Lincoln RedfaceMiller 150 STLStill need a Syncrowave and a plasma and a milling machine and a lathe and a bigger shop and a....
Reply:Originally Posted by AKwatermanIt has parallel surfaces. It clamps easily.
Reply:that is a monster table!!!!perfect for my heavy creation like the 75kg "DRAGON" i created last month ago.....and planning to make heavier ones in the future..nice work...thanks for sharing
Reply:very nice table. And i thought my welding table was cool.Well one thing is for sure is when you move that your going to need some sort of crane a fork left to put it on the truck or trailer if you move to a different  shop. nice buildMillermatic 211 with mvp plugs miller titanium series welding helmetstihl chain saws 8 ft welding table
Reply:I lke the table, clamping would be so nice.Dave ReberWadsworth Ohio
Reply:Looks good!You might consider locking the swivel on two of the casters.Carts with "twin steer"  are a pain to maneuver.Good Luck2 thumbs up.HammerFile Big Hammer------------------------------Here, let me Google that for you...
Reply:Originally Posted by denrepLooks good!You might consider locking the swivel on two of the casters.Carts with "twin steer"  are a pain to maneuver.Good Luck
Reply:Sweet set up!
Reply:Sorry it's a table?  I'm only sorry it isn't mine... Sweet.(Retired) Professional firefighter, amateur everything else I try to do...Oh yeah:  Go Big Red!   (You know: one of the 12 members of the Big 10 cuz we left the 10 members of the Big 12...)
GMT+8, 2025-12-27 05:29 , Processed in 0.073492 second(s), 18 queries .
