L-tec 250
发表于 2021-8-31 23:25:18 | 显示全部楼层 |阅读模式
Does anyone know if you can use a spool gun on an L-Tec 250?  I am looking at purchasing an L-Tec if it is possible.  I would imagine so due to them being similar to the esab 250, but I want to make sure.
Reply:yes you can,    i have one,    the spool gun is made in the USA by profax.  aec-200,   which is also made for ESAB by profax as the ST-23A.   if u get a gun tha does not have the correct plug end just order the following part number from Mauser electronics 654-MS3106F18-8Phttp://www.mouser.com/ProductDetail/...qJAciH5Q%3d%3dcurrently back ordered till aug 8th.   i have one on order myself    many of these guns have a terminal bar connection instead of a plugLast edited by soutthpaw; 07-21-2011 at 09:34 AM.Tiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:thanks!  I thought so due to them being the same machine, but before I pulled the trigger I wanted confirmation.
Reply:the plug price is less than half what buying it from profax costs.they are not just similar, they are the same machine just different colorLast edited by soutthpaw; 07-21-2011 at 09:38 AM.Tiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:how do you like your profax spoolgun?  I bought the machine and it has a profax whip.  It will be my first profax whip as all the ones I used at work were either bernard or factory whip.
GMT+8, 2025-12-27 05:28 , Processed in 0.089472 second(s), 18 queries .
