Lincoln 180hd
发表于 2021-8-31 23:25:18 | 显示全部楼层 |阅读模式
alright guys ive been mig weldin for about 4 years. ive had this welder for about 2 years. everytime i start weldin i hear a noise like someones trapped in my welder and beatin to get out. and i can get a good lookin weld outta it. ive got a 75/25 bottle. my ground is good whereever i ground it i clean the metal up before i weld. i just cant figure it out. i also switched the polarities out and im runnin .035 wire on a big spool. im just tryin to figure out why i cant get a good lookin bead.thanks
Reply:3 year warranty, I would start by calling Lincoln tech supportTiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:.035 solid is too big for that machine.get a roll of .030but in the mean timetake the.035 roll off, turn on the machine and see if you get the same soundNo sound= you probably have the Tension set too tight on the Hubsame sound, send it in for repair.One more thing, as you get towards the end of the Roll it becomes harder for it to spool offEd Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:thats probly what the noise is. i noticed the roll is all crossed and crap.
GMT+8, 2025-12-27 03:51 , Processed in 0.101067 second(s), 18 queries .
