oxy regulator
发表于 2021-8-31 23:25:16 | 显示全部楼层 |阅读模式
HelloI got a used victor portable torch set, after filling tanks discovered oxy regulator is leaking out of hole when i open main supply, should i get firepower regulator repaired or replace, any thoughts on the light duty harbour freight oxy regulator ?Thanks Mike
Reply:Id get it rebuilt ,replaced with a name brand.  unless u really wanna goto harbor freight and trust there regulators, look up oxygen regulator explosion .....Last edited by LawsonWeldingLLC; 07-26-2011 at 01:36 AM.I forgot how to change this.
Reply:I am not familiar with the regulator you have but could make a few comments.Never had gas coming out of a hole usually the problem is the output pressure creaps up or if you turn the cylinder off the needles go down while the torch knobs are off.  The guages that screw in can spring leaks as well.I took a nice big dual stage regulator to the local welding shop and paid over $90 (approx 7 years ago) to have it rebuilt.  After a while it had the needles going to zero issue and I went back to the nearest branch of the entity which bought the other entity and the same guy was there and told me I was on my own but they would sell me new guages if that would help.  So if you go the reubuild route it sure isn't likel getting a new one.Maybe the guy before you had one of the issues I mentioned and didn't put it together correctly it isn't like they are too hard to take apart.  Usually the seat ceases to seat properly.Fran
Reply:Victor is a good name in regulators, not sure what they have on their "portable set" but they may be worthwhile to have repaired.Buy the best regulators you can afford, for a home shop they will last a lifetime.Some good names are, not in any particular order: Victor, Esab (Purox, Oxweld), Smith, Harris etc"The reason we are here is that we are not all there"SA 200Idealarc TM 300 300MM 200MM 25130a SpoolgunPrecision Tig 375Invertec V350 ProSC-32 CS 12 Wire FeederOxweld/Purox O/AArcAirHypertherm Powermax 85LN25
Reply:the oxy regulator that came on my victor is a Firepower Model # FPR-150 CR,I thought victor made firepower? I will try and post a picture of oxy regulator and hole where it leaks fromThanks Mike Attached ImagesLast edited by awardmont; 08-01-2011 at 01:15 AM.Reason: wrong picture
Reply:Victor does make firepower u have a hole in the diaphragm probably. just go buy another http://www.google.com/products/catal...ed=0CEEQ8wIwBALast edited by LawsonWeldingLLC; 08-01-2011 at 01:22 AM.I forgot how to change this.
Reply:ThanksI ll go to Airgas where i got the bottles filled, I think they sell Radnor, What size bottles/tanks are these? I got this so I can try and weld a hitch to my jeep bumper which is a 1946 Willys, is that pretty soft metal?Last edited by awardmont; 08-01-2011 at 01:26 AM.Reason: misspelled
Reply:really imo dont use it to weld a hitch that will pull anything ...........let a professional do it for public safetys sake and i use radnor they are made by victor as wellI forgot how to change this.
Reply:Will do , thanks for pointing out safety issue
Reply:Originally Posted by awardmont What size bottles/tanks are these?
GMT+8, 2025-12-27 03:51 , Processed in 0.118245 second(s), 18 queries .
