tig welding with a lincoln fluxcore welder
发表于 2021-8-31 23:25:15 | 显示全部楼层 |阅读模式
has any one evey tried it? its a dc power source, looks doable. so am i wasteing my time trying it out ot what?
Reply:Try it?Nope..Waste of time?Yup.But if you do try it be sure to post pics....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:You need to understand whats going on. Yes they are both DC, but tig uses a Constant Current (CC) power source, FC or mig uses a Constant Voltage (CV) power source. It's why you can't run a  standard wire feeder with a standard tig machine..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:DSW....you can run TIG on CV power supplies.However if it has a contactor in it you're asking for problems from the beginning. Get a TIG machine and go from there
Reply:Originally Posted by BCTimberwolfDSW....you can run TIG on CV power supplies.However if it has a contactor in it you're asking for problems from the beginning. Get a TIG machine and go from there
Reply:I would think it would be easier to use semi batterys....Use a stainless pipe and vary the resistance. lol either way imo a cc welder is relatively easy to obtain for decent money. The problem i see with cv dont know if i am rite or wrong, your amperage would vary way to much to make it worth it?I forgot how to change this.
Reply:Originally Posted by DSWYou need to understand whats going on. Yes they are both DC, but tig uses a Constant Current (CC) power source, FC or mig uses a Constant Voltage (CV) power source. It's why you can't run a  standard wire feeder with a standard tig machine.
GMT+8, 2025-12-27 03:51 , Processed in 0.104787 second(s), 18 queries .
