Dump trailer
发表于 2021-8-31 23:25:13 | 显示全部楼层 |阅读模式
I have a army trailer. They pulled it behind a 6x6 truck. It had 900x20 tires.It is basecly a big heavyduty pickup bed trailer 6x9 it has fenderwells inside. I put a smaller axle with 16inch tires and lowered it about 2feet. I have always wanted to put a hoist under it so it would dump but it has no runers and i hate to put runers under it and make it setup higher. I need some Ideals on what to do. I have thought about puting runers on inside, It has crossmembers every 9 inches. Or I have a good 8x9 flat bed that I could build a dump trailer with. I haul a lot of brush dirt rock in my army trailer and i would like to unload it easyer.
Reply:Can you post some specific photos of what your working with?  There are a few dump trailers on the site, you will find one if you search my username.
Reply:Does it look like these? These are M105's, the bud wheels use 6 lugs as opposed to the smaller M101's which have 5 lug wheels. I borrowed the photo's from the Steel Soldiers board at the link...http://www.steelsoldiers.com/trailer...eel-width.html Attached ImagesCity of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:Its a M105 it now has 8 hole wheels. I have lowered it as much as i can with the factory springs. I wish it was lower.
Reply:I have one of those axles in my back yard.  I was planning to make a dump trailer out of it too.   If yours has the handbrakes for each wheel you could just move the a frame and attach it to the front of the box with the pintle via a hinge.   Then to dump you just apply the brakes and back up and the trailer will dump.   No hydraulics etc needed.   If u only dump occasionally then its a cheap way to make a dump trailer Sent from my SPH-D700 using Tapatalk 2Tiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:Are the springs still on top of the axle? Could you put the springs under the axle & still have enough clearance btwn the wheel & fender? You have a good idea though, making it into a dump trailer!
Reply:The fender are know problem but thier is only 4inches between spring and frame and I think axle is 3inch pipe so you would have 1inch of spring travel.So i lowered spring hangers and put axle on top of springs. It lower it a little. I hate to get new springs but that would lower it. It seats so high that a jack is a problem. I put one on it a regular trailer jack I know it was not a good deal it got bumped one day and it riped frame. I use my pickups crane to lift it.
Reply:This is how my brother-in-law did it.  It works great, We load lawn tractors and haul gravel. Is is pretty much all purpose."G"Last edited by ConductorX; 04-23-2012 at 01:29 PM.ConductorX - The Volkswright Shophttp://volkswright.blogspot.com/http://bugwerks.blogspot.com/Miller DVI w/Spoolgun - Miller Plasma Cutter
GMT+8, 2025-12-27 03:51 , Processed in 0.177722 second(s), 18 queries .
