Some stainless Tig
发表于 2021-8-31 23:25:11 | 显示全部楼层 |阅读模式
Hey All, Here are some pics of a stainless heat exchanger tube I made for a small diesel sailboat engine. The first pic is of just the inside tube welded to the flange and the others are of the complete part. Not as good of a tigger as some of you guys that I see on here so opinions are welcome  Thanx and Happy welding Attached Images
Reply:Forgot to mention the flange I made allows the smaller pipe to fit tightly and I put it a 1/8 in the middle made for a nice set-up to weld.
Reply:What is the alloy?  Stainless is so sensitive to everything in salt water but the weld looks clean (no black) and that is the best start.
Reply:Originally Posted by 76GMC1500What is the alloy?  Stainless is so sensitive to everything in salt water but the weld looks clean (no black) and that is the best start.
Reply:Originally Posted by powerThanx! I did not ask the alloy? The business brought me the material and the drawings.
GMT+8, 2025-12-27 03:53 , Processed in 0.306081 second(s), 18 queries .
