thermalarc raider 100000 pro with a spoolmate 30a and a wc24?
发表于 2021-8-31 23:25:09 | 显示全部楼层 |阅读模式
will a miller spoolmate 30A/wc24  hook up to the thermal arc 10000 pro 14 pin connection?
Reply:duaneb! duaneb! you there?
Reply:5.07 14 pin Receptacle SignalsSocket Pin FunctionA24VAC auxiliary high side.B Input to energize solid state contator (Contact closure between pin A and pin B)C 5k ohm (maximum) connection to 5k ohm remote control potentiometerDZero ohm (minimum) connection to 5k ohm remote control potentiometerE Wiper arm connection to 5k ohm remote control potentiometerF Not UsedG 24/115 VAC circuit common, also connected to chassisH Not UsedI 115 VAC auxiliary high sideJ 115 VAC input to energize solid state contactor (Contact closure between pin I and pin J)K Chassis groundWC-24/     A+B, and G are used. It will work..Last edited by Brand X; 12-09-2013 at 10:39 PM.Esab/Lorch ET-220iEsab 160i caddyThermal LM-200 Lincoln feedersThermal Pee-Wee 85sThermal 60i- 3phase /RPC powered (Beast)Thermal Drag-gun 35CINE 1500 Klutch 140i
Reply:great! thank you brand x
GMT+8, 2025-12-27 05:28 , Processed in 0.214858 second(s), 18 queries .
