Running a Hobart Handler120 off a gas power Lincoln
发表于 2021-8-31 23:25:05 | 显示全部楼层 |阅读模式
The  Hobart owners manual says it requires 24 amps or 20 CSA rated. Im not sure if Im reading it right or wrong on the Lincoln if it capable up to 20 or 52 amp on a plug....thanks jim Attached ImagesEsab Multimaster 260Esab Caddy160IEsab 161 STLESAB powercut 650Esab 220i tigLincoln Precision Tig 225Lincoln IdealArc 250INE SKYLINE 1500Klutch 140iMEASURE TWICE IS FOR MORONS
Reply:"The Hobart owners manual says it requires 24 amps " What is the rated output of the welder at 24 amps?If you are running a small diameter wire, then the welder is going to draw less amps. (volts x amps= watts).  There has to be some type of circuit breaker on the 115V outlet?  Plug it in and try it out.  If you are trying to weld something that requires you to turn the welder up on high, then you will have problems running it.Syncrowave 350 LX TIGRunnerThermal Arc Power Wave 185 TSWXMT 304/12VSESAB Powercut 1500MultiMaster 260MM 200
Reply:Doing some mobile sheet metal welding? Seems like you have a perfectly capable stick welder that will beat just about anything that the HH120 can dish out. Just curious. Eric
Reply:Heliarcman   looks like  @ 90 AMPs its 24 and @70 its 20..Im wanting to build a shade canopy on the lower part of my property and im looking at using 16 gauge tubing,I know it will go alot faster with flux core vs stick.So with the Hobart I will be on a lower setting doing 16 gauge I take it I shouldn't have a problem?         thanks jimEsab Multimaster 260Esab Caddy160IEsab 161 STLESAB powercut 650Esab 220i tigLincoln Precision Tig 225Lincoln IdealArc 250INE SKYLINE 1500Klutch 140iMEASURE TWICE IS FOR MORONS
Reply:You'll be fine but 16g with Fluxcore ain't no fun.Last edited by Broccoli1; 08-06-2011 at 11:07 AM.Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
GMT+8, 2025-12-27 03:53 , Processed in 0.094266 second(s), 18 queries .
