welder dont weld???
发表于 2021-8-31 23:25:04 | 显示全部楼层 |阅读模式
I have a Century powermate 70 MIG wire feed welder I just got today. I plugged it up and grounded it and when I went to work nothing happened but the wirefeed just pushed out wire when I squeezed the button. I can count on one hand the number of times I've fiddled around with welding so I didnt keep trying today. but would a bad ground cause such a thing to happen? or is the welder most likely broke?
Reply:If you have a good ground connection and still can't get an arc, test voltage (with a multimeter) between the gun tip and the ground clamp when you squeeze the MIG trigger.
Reply:can I ground to a car battery?
Reply:Huhhhh?????? Attached Images
Reply:Originally Posted by Premirecan I ground to a car battery?
Reply:I plugged it up and grounded it and when I went to work nothing happened
Reply:This is why every time someone refers to the work clamp/lead as "ground", I die a little inside.Joedirt, best use of a lolcat on WeldingWeb, ever.Visit Tensaiteki.com
Reply:Yes ground it to the car battery and open all the caps on the battery. Then you need to hold the gun pointed at the positive terminal of the battery and pull the trigger.  This procedure ensures that the next generation is smarter than the last.
Reply:hahaha FB. Darwinism FTW
Reply:on a smarter note anyone know where i can get the pc board schematic for a century 117-018 board part # 860-614-666 plz
Reply:Originally Posted by joedirt1966Huhhhh??????
Reply:Send me your e-mail address by private message and I can send it to you.Put the pcb number in you message. So I don't have to look for it.If you want the owners and parts manuals, include the welder model number.
Reply:ok that is not all that bad lol car battery  i use to use a Lincoln pipeliner to jump start a an old 6x6 m35 set it to 200 amps and set volts to 24 and fire in the hole lolLincoln Power Arc 4000 Thermal Arc Fabricator 252 iThermal arc 186Thermal Arc 26 tigTweeko 200 amp spool gunHobart AirForce 400WP-17V-12R
Reply:Originally Posted by assassin_worksok that is not all that bad lol car battery  i use to use a Lincoln pipeliner to jump start a an old 6x6 m35 set it to 200 amps and set volts to 24 and fire in the hole lol
Reply:Originally Posted by MikeGyverI killled a forklift's battery at a job site once and used a CV welder set to 12v to jump start it when nobody important was looking
Reply:This is a troll...... rightIs joke ....yesBacked my CATMA over your CARMA oops clusmy me  What would SATAN do ?? Miller Trailblazer 302 AirPakMiller Digital Elite  Optrel Welding HatArcair K4000Suitcase 12RC / 12 VSHypertherm PM-45Rage 3 sawRusty old Truck
GMT+8, 2025-12-27 03:53 , Processed in 0.104294 second(s), 18 queries .
