Lincoln Tig Water cooler hook up question!!!
发表于 2021-8-31 23:25:04 | 显示全部楼层 |阅读模式
So i have a Precision Tig 225 and a Cool arc 40 water cooler.  anyone know the part numbers for the water lines from the "power adapter" to the cooler?  the parts list in the cooler instructions shows a nice dumb diagram, but lists no part numbers for that power adapter or lines.....   i have a nice Crafters series torch kit id like to use! :-)local welding shop is no help..jake
Reply:wow   some local  welding shop .>Innovations are what i leave behind for History
Reply:K1622-4, adapter.  went back and talked to some one else.  that should be it.
GMT+8, 2025-12-27 03:53 , Processed in 0.076026 second(s), 18 queries .
