lincoln 140hd not penetrating
发表于 2021-8-31 23:24:56 | 显示全部楼层 |阅读模式
Lincoln140 hd welds look good but it will not penetrate its just sitting on top  and when I break the welds apart it's all porosity underneath and now it won't feed on high power I would hate to take it in since they charge so much for service any help would be great
Reply:Double check the polarity and proper gas.Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:-How thick is the metal you're trying to weld?-Are you using flux core wire or MIG with gas?     -If MIG with gas, does your cylinder have gas?          -What is your gas regulator pressure set at?-What is the amperage output on your electrical outlet youre plugged into, 15, 20, 30 ????-What do you mean by "won't feed on high power?       -Does the machine turn on?            -Cooling fan come on?                  -Is the wire drive motor doing anything when you pull the trigger?Help us out a bit and give us more details.Lincoln Power Mig 216Lincoln AC/DC-225/125Miller  625 X-Treme PlasmaMiller 211 Forney 95FI-A 301HF 91110Victor Journeyman O/PMilwaukee DaytonMakita  Baileigh NRA Life Member
Reply:Get a 220 volt welder those 110 machines wont penetrate at all.Lincoln pro core 125 14''chop saw7 inch grinder,2-4.5 inch grinders,electric die grinder.Half inch drillAnd alot of hand tools
Reply:1/8 inch steel might with gas plenty of power I work in industrial and I brought it to work to see if it was a power issue it lays a good bead but just sits on top I use a miller 250 everyday at work and I never have a problem I'm just going to buy a bigger welder I've had the Lincoln for 7 years probably just worn out
Reply:How can it "lay a good bead" and yet the bead just sits on top and be porous?  That would not be what I call laying a good bead.  Rather than just going out and buying a bigger welder, you might consider answering some of the questions that SuperArc asked, and maybe we can help you.  Just take a second to respond, and then listen for a minute to some of the replies.Miller Dynasty 200 DXMiller CP-300 with 30A feederHypertherm Powermax 900Oxy-fuel w/Harris torchesScotchman Glide-in bandsawMonarch 10EE latheEmi-Mec Autoturn latheDeckel FP2NC milling machinePro-Tools 105 Bender
Reply:Fan comes on it feeds fine on low setting when I turn it all the way up it quits feeding I've run the gas at every setting I could and it does look like a good weld it just isn't penetrating that is my question how is that possible
Reply:What is the base material?HAve you welded on this same piece of base material in the past?What is the surface condition of the base material?
Reply:New cold rolled steel welded it many times could it be I got a bad tank of gas I just got it
Reply:I'll post a picture when I get a chance
Reply:Is the gas actually coming out? Hose kinked or plugged maybe?HH 187Miller Bluestar1EAHP AlphaTig 200X
GMT+8, 2025-12-27 03:53 , Processed in 0.094349 second(s), 18 queries .
