Handmade metal cutting band saw rebuild
发表于 2021-8-31 23:24:49 | 显示全部楼层 |阅读模式
I got this heavy 3 wheel band saw a couple months ago off of c-list for a $100, someone else built it years ago. Some one else changed some things on it,but didn't really know what they were doing.... they added a jackshaft and some other hacked up mods. Anyway, it is built with all vintage parts, two heavy cast iron wheels,one light aluminum wheel, an old Dayton gear drive reduction motor.... The plan is to remount the motor, raise the upper part of the "C" for more cutting capacity, clean it up and paint it... Attached ImagesLincoln pro mig 180Lincoln Square Wave Tig 300/wp 20/home built water cooler Victor, Purox, Harris, O/A welding/cutting setupsVintage Craftsman drill pressVintage Craftsman/Atlas 12"x 36'' lathe7''x 12'' w/c band saw Everlast 140 st
Reply:looks like a great way to lose an arm lol
Reply:Yeah, Nader,or OSHA probably wouldn't approve.... I am going to make a shroud for the blade, I forgot to mention that....Lincoln pro mig 180Lincoln Square Wave Tig 300/wp 20/home built water cooler Victor, Purox, Harris, O/A welding/cutting setupsVintage Craftsman drill pressVintage Craftsman/Atlas 12"x 36'' lathe7''x 12'' w/c band saw Everlast 140 st
Reply:Haha yea a guard would probably be a good idea.  yea im sure that machine breakes every osha,msha, law out there lolIt looks like shell serve the purpose though.
Reply:looks good but scaryLincoln Power Arc 4000 Thermal Arc Fabricator 252 iThermal arc 186Thermal Arc 26 tigTweeko 200 amp spool gunHobart AirForce 400WP-17V-12R
Reply:Is this going to be for wood or metal? The deep throat on that saw looks to be quite useful however compared to most 12-14" saws. If you raise the arm are you going to a longer blade as well to maintain the deep throat?.No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Originally Posted by DSWIs this going to be for wood or metal? The deep throat on that saw looks to be quite useful however compared to most 12-14" saws. If you raise the arm are you going to a longer blade as well to maintain the deep throat?
Reply:So I finished rebuilding my band saw... I raised the upper arm about 4'', remounted the motor, made some blade guards, installed a smaller third idler wheel which allowed me to use the same length blade, and added some dolly wheels so I can move it around easier The saw works excellent, it cuts very nice... cuts through 3/8 or 1/2'' like its nothing.  Now all it needs is some paint...so far all I have into this project is $100 for the saw, $30 for two swivel dolly wheels, and $40 for a 1014 steel blade. Attached ImagesLincoln pro mig 180Lincoln Square Wave Tig 300/wp 20/home built water cooler Victor, Purox, Harris, O/A welding/cutting setupsVintage Craftsman drill pressVintage Craftsman/Atlas 12"x 36'' lathe7''x 12'' w/c band saw Everlast 140 st
GMT+8, 2025-12-27 05:18 , Processed in 0.090685 second(s), 18 queries .
