hey everyone, im looking to get a basic welding cert, maybe SMAW 2G or 3G, how much should i expect to pay? how do i go about finding a place that i can do the test? im in CT thanks in advancePhil http://www.philswelding.com
Reply:Where in CT? http://www.aws.org/w/a/certification/ATF/http://www.aws.org/certification/CW/
Reply:middletown Ct http://www.philswelding.com
Reply:the last time I tested that I had to pay was 150.00 out of Pittsburgh. See non distructive testing in your area they should be able to quote and setup a test. before spending the money know you are able to pass because it's 150.00 pass or fail.
Reply:Check out these guys, http://www.trieng.com/Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:When I first needed a cert in 2007 when I got back under the hood I looked around for a place that allowed me to grind on the test plate. I know I know Booo!!! But if a guy is trying to get a job and is tight on money its an option. At least he can show the cert make some money and build from there I'm going to do the thing that God put Galen Beasley on this Earth to do:Have Salon quality hair and weld.Nothing like a good cup of coffee and the smell of 6010 burning in the morning. 971-204-3444 cell API ASME Structural NDT and Repair
Reply:I've never been able to use a grinder on a smaw structural plate test. If you do a pressure pipe test, you will be allowed to use a grinder. What do you wish to do with your ticket? What type of work?JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:if you want to go structural do your 3g 4g 1 inch platesMiller Xmt 350Lincoln Ln-25Ahp 200xSmith Gas Mixer AR/HTig is my Kung FuThrowing down dimes and weaving aboutInstagram http://instagram.com/[email protected]
Reply:@ MetalMan23 - you intending to go 3/8" (certified up to 1/2" thickness) or 1" (unlimited thickness)? Currently in the same boat as you, 'cept planned to go 3/8" based on the economics of acquiring test samples needed for the test. Prob a bad move on my part. Low-cost 1" mild steel is rather costly in my area. 3/8" and 1/4" plate & backing samples, on the other hand, are easy to rip as drops from local steel suppliers. But as WeldorWes eludes to, 1" is the way to go. One and done. If decide to rip the unlimited, then will adopt a "train like fight" approach and burn rods exclusively on 1" plate.Planning to complete the AWS 3G test before Mar'14 and interested to hearing your attack plan Last edited by ManoKai; 12-16-2013 at 05:12 PM."Discovery is to see what everybody else has seen, and to think what nobody else has thought" - Albert Szent-Gyorgyi
Reply:Correction: the 3/8" thickness 3G test certifies welding on steel thickness of 1/8" to 3/4"."Discovery is to see what everybody else has seen, and to think what nobody else has thought" - Albert Szent-Gyorgyi
Reply:Originally Posted by MetalMan23hey everyone, im looking to get a basic welding cert, maybe SMAW 2G or 3G, how much should i expect to pay? how do i go about finding a place that i can do the test? im in CT thanks in advancePhil |
