Cutting tips sizes
发表于 2021-8-31 23:24:46 | 显示全部楼层 |阅读模式
My Victor cutting torch tip is marked 0-3-101. I have tried to match that up with the metal thicknes tip size charts and for me it does not compute.Could someone translate the numbers into usable information for me?Doing the best I can with what I got
Reply:http://www.eurekaoxygencompany.com/victor.htmBubble gumTooth pixDuct tapeBlack glueGBMF hammerScrew gun --bad battery (see above)
Reply:Originally Posted by CharliekiloMy Victor cutting torch tip is marked 0-3-101. I have tried to match that up with the metal thicknes tip size charts and for me it does not compute.Could someone translate the numbers into usable information for me?
Reply:RTFM.  OR go to the Victor website and get the FM. And then read it.A size #0 3-101 Victor cutting tip is used to cut 3/8" to 1/2" material.  A bit of an overkill for thin sheetmetal (use a #000 for that).  btw, it is an acetylene tip.  Other fuels use a different tip.  Also, if using a fuel other than acetylene, make sure to use "T" grade hose.  The best laid schemes ... Gang oft agley ...
Reply:Originally Posted by Burpeehttp://www.eurekaoxygencompany.com/victor.htm
Reply:A 101 is a general-purpose type of Victor acetylene cutting tip.A 3-101 fits the medium-duty torch heads, as opposed to the 1-101 which is for the heavy-duty Journeyman type torches.The very first number indicates the orifice size. So you have a tip size Zero. Our Victor Performer Series kit came with a 0-3-101 cutting tip."USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:Thank you. Now I know how to read the numbers.Doing the best I can with what I got
Reply:Originally Posted by CharliekiloThank you. Now I know how to read the numbers.
GMT+8, 2025-12-27 05:16 , Processed in 0.194333 second(s), 18 queries .
