Pqr - a304 plate thk:10
发表于 2021-8-31 23:24:45 | 显示全部楼层 |阅读模式
Dear ProfessionalsI have to run a pqr on A304 plate thk:10 to A304 plate thk:10  i use smaw proccess and 308l filler metal and a pqr on A304 plate thk:10 to st37-2 plate thk:10Please send general points(pre heat temp recommended joint detail and ...)  to improve the quality of the pqr . thanx for your help.
Reply:Originally Posted by metall64Dear ProfessionalsI have to run a pqr on A304 plate thk:10 to A304 plate thk:10  i use smaw proccess and 308l filler metal and a pqr on A304 plate thk:10 to st37-2 plate thk:10Please send general points(pre heat temp recommended joint detail and ...)  to improve the quality of the pqr . thanx for your help.
GMT+8, 2025-12-27 05:18 , Processed in 0.093214 second(s), 18 queries .
