I'm going to be using a 120v Mig welder. What size gallon air compressor do I need to make a decent smoker? For a friends birthday present. Any tips and tricks making these?!?Lincoln 140 Pak MIG Everlast powerarc 140 STLincoln Tombstone
Reply:look up chucke2009 on youtube. He has built and documented at least 3 or 4 smokers, it should give you some good tips.- Christian M.C3 Welding & Fabrication - CNC Plasma Cutting-Mobile Welding-Custom welding and fabwww.c3welding.com
Reply:Originally Posted by camjeep3look up chucke2009 on youtube. He has built and documented at least 3 or 4 smokers, it should give you some good tips.
Reply:Originally Posted by rockcrawler97 Any tips and tricks making these?!?
Reply:When I built my smoker I used the ratios stated here:http://webpages.charter.net/tomchism...%20form%20.xlsto size my fire box, vent size, opening from fire box to cooker, and chimney volume. Everything worked out for me, I can control my temperatures and the chimney draws good.
Reply:http://www.thesmokering.com/forum/Check out this web site. Lots of builders in the cooker section. They also have a ratio calculator. Be sure to follow it. I like the size of that reverse flow. I built mine from a 250 gal. Tank. Works great just a lot of smoker.Dan. D.Last edited by DanD78; 12-18-2013 at 10:08 AM.
Reply:I was wondering when someone was going to mention thesmokering. I'm also surprised someone hasn't suggested a UDS yet..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Originally Posted by tackitHow does the chimney work, it's right under the fire box? Nice looking smokers Fern.
Reply:I had no idea there were folks using compressed air to make good BBQ.Last edited by weldertom; 12-18-2013 at 12:58 PM.
Reply:Hi, try this website also, http://smokerbuilder.com/forums/ they have a link for smoker plans that you can buy also. |
