E70T-5H question
发表于 2021-8-31 23:24:42 | 显示全部楼层 |阅读模式
Hi, I am looking for some pointer/input from experienced welders that have used a dual shielded E70T-5H wire in the 3/32 size range, and an .045 E71T-1 dual shield wire.I am going to be taking a visual performance test and then visual/radiological test in a few days with a wire that I have never used.  I am not overly concerned about the process of the test, however, I have never used the E70T-5 wire.  I have much experience with the E71T-1 wire though.How does the T-5 run?  I have heard that is is very similar to 7018 LH stick, is that true?  If this is true, what are the similarities?  What is a good drag angle?  What about stick out?  The only real information that I have is about 40 degrees drag angle and 3/4 to 1" stick out.Are there any good, important pointers any experienced welders could provide to me?  I certainly appreciate your help.
Reply:Nothing?  TTT
GMT+8, 2025-12-27 05:18 , Processed in 0.094364 second(s), 18 queries .
