For those who use spool guns for aluminum welding, if you are hold the grip with your right hand, are you using your fingers of your left hand to slightly support/control the tip as with a welding rod? I've seen people just using the handle, but the distance to the point of welding would seem to make it hard to make finer movements. Thanks
Reply:Sure. Any time I can use 2 hands, I do, with almost all welding processes. Much more stable. |
