Some semi-conductor chambers
发表于 2021-8-31 23:24:39 | 显示全部楼层 |阅读模式
[ame]http://www.youtube.com/watch?v=mdMAgXK6FN4[/ame]  Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
Reply:Looks good, now you can afford a decent camera! (I know...I'm one to talk) Welding/Fab Pics: www.UtahWeld.com
Reply:Funny you mention a better camera..... There areSo many to choose from what do you recommend ?  Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
Reply:omg, what happened over there? forgot to open the gas bottle ????--------------------------------------------------------------www.becmotors.nlyup, I quit welding.. joined welder anonymous
Reply:Originally Posted by Donoharmomg, what happened over there? forgot to open the gas bottle ????
Reply:didn't get that one, did you????--------------------------------------------------------------www.becmotors.nlyup, I quit welding.. joined welder anonymous
Reply:You get all the fun stuff.Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:Originally Posted by Donoharmdidn't get that one, did you????
Reply:BC, when you welded the triangular shaped pieces (angle iron?) to the top of the chambers, looks like about 2" stich weld every 4" or so.Do you back purge something like that?Con Fuse!Miller Dynasty 350Millermatic 350P-Spoolmatic 30AMiller Multimatic 200Hypertherm PowerMax 1000G3Miller Maxstar 200DX
Reply:Originally Posted by B_CFunny you mention a better camera..... There areSo many to choose from what do you recommend ?
Reply:I find it odd that the fore line tube had a simple KF flange fitting, while the smaller ports were Con-Flat. The latter is used with vacuum chambers that achieve a higher vacuum, while the KF style is for rough vacuum.KF is a simple metal ring with a rubber o ring that sits between the two pieces and has an external clamp to compress them together. The Con-Flat has a copper gasket that sits on a lipped edge and then 6 bolts crush the two sides.I was a semiconductor equipment tech for 25 or so years.Lincoln Idealarc 250 (circa 1962)Lincoln Weldpak 155 w/Mig KitLincoln Squarewave TIG 175
Reply:Hmmmmmm that's all GREEK to me Bro, I just weld stuff.......  Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
Reply:Originally Posted by Broccoli1Nothing really that wrong with the Phone Camera you are using: the problem is that you are just not a very good Camera Operator SLOW down on the filming, that camera doesn't have the guts to keep up with fast camera movements so you get the Pixelating. Even if you had a better Camera, you shouldn't move that quickly.Give us some time to enjoy the Filming of the subject- of course don't go so slowly we fall asleep but definitely slower than what yer doing now.And.... TURN OFF the radio in the background
Reply:Originally Posted by B_CHmmmmmm that's all GREEK to me Bro, I just weld stuff.......
Reply:Nope.............  Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
Reply:wow this phone/camera does work good......Hell-O.....Can you hear me now?  LOL  Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
Reply:Papaharley is correct in that the chambers should have a consistency of port configurations or types of connections.  KF is obviously for evacaution pumping but those conflats are most likely for vacuum level gauges?   Gauges come in both 'flavors' for ports.  Is this a commercial chamber or R&D?  Semiconductor is one word, no hypens :-).  Very nice welds!
GMT+8, 2025-12-27 05:18 , Processed in 0.094371 second(s), 18 queries .
