bevel adapter for plasma cutter
发表于 2021-8-31 23:24:37 | 显示全部楼层 |阅读模式
I have a need to make compound miter cuts in some 2" x 4" steel tube.  Saw cutting is out of the question, so I made this adapter to fit my plasma cutter.  The torch fits the adapter snugly with no need for a set screw, and it is adjustable 45 deg. left and right.  Its nowhere near as clean or easy as a Haberle H90 coldsaw, but it didn't cost 14 large either. Attached Images
Reply:I am trying to understand how it works.  Any pics of it in action?Miller Diversion 180Hobart Handler 140 (Soon to be replaced with Miller 211?)Miller Spectrum 625 Extreme
Reply:no pics yet in action, but I'll attempt a description....the torch goes in the hole, and the edge (left) of the base gets dragged along a straightedge.  To adjust the angle, just loosen the setscrew and pivot the torch to the desired angle.
Reply:Gotta watch the auctions!  I picked up my H350 for $280, probably the best money I've ever spent on equipment
Reply:Lucky guy!  The H350 still won't do compound miters though
GMT+8, 2025-12-27 05:28 , Processed in 0.070264 second(s), 18 queries .
