OA cart
发表于 2021-8-31 23:24:37 | 显示全部楼层 |阅读模式
Work in progress, building this small cart for OA, light duty welding/cutting. Got a gas saver, Henrob DHC2000 and normal small torch. Place for the fire extingusher and accesories etc. The strap is temp to check the spacing and all that, will be replaced with proper hold down bracket.More pictures here: http://www.flickr.com/photos/sarel_w...7624661813246/Rgrds
GMT+8, 2025-12-27 05:45 , Processed in 0.111639 second(s), 18 queries .
