Stainless Rose Trellis
发表于 2021-8-31 23:24:36 | 显示全部楼层 |阅读模式
Haven't posted nor welded in a while, but I had one of those days where for no reason at all, you pick #817 on your to-do list and scratch it off.  I made this stainless trellis for the climbing rose behind my garage.  Barely any welding in it, just a bunch of tacks.  I don't know how to make pretty stainless tacks so these are all grey.   At one point, I thought my Speedglas hood was broken.  It kept darkening out of the blue.  Then I realized the garage door was up, and it was sensing the lightning flashes from the thunderstorms rolling through.  It's just a really long arc, dummy!   And finally, in situ...   Like all my projects, it took me far longer than it should've... but I think it looks acceptable, and will probably outlive me.__David Hillman
Reply:Nice trellis David. How much does that rose bush climb?
Reply:Originally Posted by DanTNice trellis David. How much does that rose bush climb?
Reply:Nice Job David! Who cares how long it takes!! end results will make up for it!! My motto anyhow
Reply:Looks good, my hood will shade if I turn my head to fast not even looking at the sun.Haven't been out in a storm.  Have to weld outside for now.
Reply:Nice design D.H. Where did you score the S.S. from?
Reply:Originally Posted by sky hy ironmanNice design D.H. Where did you score the S.S. from?
GMT+8, 2025-12-27 05:39 , Processed in 0.092943 second(s), 18 queries .
