tilt a flat table top
发表于 2021-8-31 23:24:34 | 显示全部楼层 |阅读模式
I want to build a drafting table but hey i want something artsy.Trying to think of some type of right i can turn a wheel and get the table to tilt? ideas?
Reply:I've seen a few commercial ones like this. Bike chain and sprocket comes to mind right away as the tilting mechanism.  Big thing to work out is how to keep the table at the angle you want it to stay at. Typically designs use friction clamps like knobs to lock things in place. Tilt table, then tighten the knobs to lock the angle. I've also seen pins used in holes to lock the angle. I can see the typical bent curve with a slot and knob set up working, but if you go with a bike chain rig, you might be able to use the bike brake to lock the chain mechanism.I'll be curious to see what you come up with. I've been playing with designs for an art table of and on for a year for my aunt who paints. I just need her to pick a design and agree on the cost of materials. I'm sure I can do it for what a commercial one costs if not less. ( my labor would be free , well a gift anyways).No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Originally Posted by DSWBike chain and sprocket comes to mind right away as the tilting mechanism.  Big thing to work out is how to keep the table at the angle you want it to stay at.
Reply:Think more along the lines of an a Frame drafting Desk that has 2 post extended. I want sometype of crank on the front or side that i can adjust the angle of the tilt.
Reply:http://estore.sjf.com/sjf.nsf/0/AD47...ount=5&EndVarsthats about what i want just not sure of the mechanism that is under the damn thing
Reply:Ok i have something that will work and look fantastic. i just need to find a cheap supply of 24" gears to cut in half and the spur gear that matches themGuess i could have it cut out of aluminum on a water jet and then age it etc..
Reply:Use a worm gear it will not turn backwards.brad
Reply:That will take some serious thinking.A Liberal is someone who lives in a gated community with private security,  but says that a boarder fence won't work and people don't need guns for self protection.
Reply:I am thinking worm gear too.  Sent from my SPH-L900 using TapatalkMultimatic 200Ellis 1800Haberle S225 9" cold sawMM 300;  Spoolmate 30A w/ WC-24TB 302GDynasty 280 DX Tigrunner
GMT+8, 2025-12-27 05:38 , Processed in 0.090953 second(s), 18 queries .
