Just bought this machine and when you turn on the ignition switch the fuel pump/ injector pump? Makes a constant clicking noise? Anybody know if this should be a concern or an issue with these welders before I swap machines for my truck?
Reply:Relax amigo. Help is on the way(it's 328 AM where I am). The guys here have tons of those....BTW, the best welding machines on Earth. The red seal is one of the best engines ever made.Bubble gumTooth pixDuct tapeBlack glueGBMF hammerScrew gun --bad battery (see above)
Reply:Sounds like a typical electric fuel lift pump operation based on the information available.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Okay, thank you, do I need to use one of the 2 types of Diesel engine oil or just use conventional oil?
Reply:definately use a diesel oil in a diesel, they have extra additives that are made to deal with the extra soot in the oil, regular car oil will not hold up well and may cause damage down the road. Don't worry about getting anything fancy, Rotella or Delo have excellent reputations. Surprisingly the walmart brand Supertech has proven itself pretty capable.
Reply:I use 15W40 diesel oil in all my diesel engines, including the Deutz's in my welder and air compressor. It's not ideal for winter, but I usually warm the engine compartment before starting them, unless I'm pressed for time. Also, I don't use them that often either, but I hope that will change."Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:When purchasing oil for your diesel engine you should look at the API category designation printed on the oil container. The currently produced API category designation of oil "formulated for diesel engines" is CJ-4.The API category designation for diesel engine lube oil will always begin with the letter C. The second letter (and any suffix numeral) identifies the API "status" based on when it was put into effect and the production years range of the engines it was aimed at when it was first put into effect.Oil produced for gasoline engines has an API category beginning with the letter S. Category S oils can be used in gaseous fueled engines (propane, natural gas) also. Attached ImagesLast edited by walkerweld; 12-23-2013 at 12:09 PM. |
