brazing with tig
发表于 2021-8-31 23:24:30 | 显示全部楼层 |阅读模式
I once knew a guy that could braze with a tig welder, I watched him do it.  I have tried and failed a few times now many years later.  Anyone have any experience to share?
Reply:I have TIG brazed steel components using silicon bronze filler, trade name Everdur.  Since this is brazing, not welding, you do not melt the base metal, only the filler metal.  The application I had was joining a small cylinder onto a sheet metal door as part of a hinge.  This was a fillet joint, and I simply held the filler laying in the joint, and ran the arc along the filler with enough current to melt it and allow it to wet to the base metals.
Reply:Pulser,  DCEN?  was the filler coated or plain?
Reply:i use silicone bronze with my tig alot
GMT+8, 2025-12-27 05:38 , Processed in 0.197522 second(s), 18 queries .
