welding noob (tig)
发表于 2021-8-31 23:24:29 | 显示全部楼层 |阅读模式
hi guys! Well as the title states i am a tig welding noob. I've been on here a few times just but just as a lurker looking for some helpful info, and now i realize i totally should have registered awhile ago..  but anyway a brief history on my welding skills or lack there of lol. i took welding 1&2 in my senior year of high school, touched on the basics of oxy/acetylene, stick and mig as well as the usual how use simple fabrication tools. fast forward to now, i have not really done a lot welding in the last few years but i still know my way around a welding machine and i have cobbled together some exhausts and random pieces. i have a portable 110v mig that i have been using for real light stuff. but i'm getting into more technical pieces that are better made with a tig welder. so recently i acquired a miller diversion 180 and a few accessories and i'm learning how to use it. . and i'm looking for a little coaching and advice from all of you know-it-all's SO........... my current project is a set of turbo manifolds for my car. material: 304 stainless butt weld fitting 1.5 inch schedule 30 pipe.(now i have not actually burned the 304 yet as i am practicing on some 316L pieces that are similar in dimensions.)  i'm using my diversion 180, settings are  90A, 20 cfh 3/32 gray tungsten (that's what my welding store sold me) ground to a sharp point and 3/32 316L filler rod. i feel like i may have to concept of how to tig but i'm totally a noob so all suggestions are welcome  here are some pictures.  BEADS ON TUBE (2 without filler)there is this very fine film forming on top of the weld once it starts cooling that isn't normal is it?(4th weld up)another shotlet me know what you think!thanks,marc
Reply:is it just me or are the last few parts of my sentences cut off on the screen?
Reply:Originally Posted by audi2nris it just me or are the last few parts of my sentences cut off on the screen?
Reply:Originally Posted by TensaitekiThis forum uses a fixed-width layout. If your pictures are too large they break the layout and some of your text becomes unreadable. Post smaller pictures or post thumbnail versions that link to the full size image.
Reply:Your running too hot and not pushing enoughFiller, I don't like 316L for 304.....if you migWeld your manifold use 308 SL it wets outbetter and is easier to run.....If your TIG Welding Use 308 L and a gas lens with 1/16 tungsten Ceriated works goodLast edited by B_C; 08-26-2011 at 12:42 AM.  Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
GMT+8, 2025-12-27 05:37 , Processed in 0.096009 second(s), 18 queries .
