scored a table today
发表于 2021-8-31 23:24:25 | 显示全部楼层 |阅读模式
I got a table from a coworkers husband today.  It is 4'x4' with a 1/2" top stands at 41" tall.
Reply:you can drop that off at my place any time. I've been waiting for it.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:It weighs like 500 lbs, so i'm not moving it around that much until i get some casters for it.  It took three guys, a moving cart, atv winch, and my atv lift jack. To get if off the trailer and in the garage.
Reply:I'd have gone with an engine hoist.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:Sweet table.  I just got this mammoth the other day.  The top itself weighed 500#'s.  I should have made it taller, but I already had this cart lying around so I decided to use it.  It gives me an excuse to buy another table one day. Attached Images
Reply:Dayum! Is that really 1.5" thick?  I'm impressed!   Trying to find thick one like that around here, but I can't weld if I have to trade an arm and a leg for it!
Reply:Pruav, is that top wood or steel? If its wood, it could easily be replaced with 3/8" or thicker steel for welding.  Heck, 1/4" would work too if you have weight concerns.Lincoln Power Mig 216Lincoln AC/DC-225/125Miller  625 X-Treme PlasmaMiller 211 Forney 95FI-A 301HF 91110Victor Journeyman O/PMilwaukee DaytonMakita  Baileigh NRA Life Member
Reply:Originally Posted by SuperArcPruav, is that top wood or steel? If its wood, it could easily be replaced with 3/8" or thicker steel for welding.  Heck, 1/4" would work too if you have weight concerns.
Reply:Originally Posted by pruavsteel.  The top alone weighs 330 lbs
GMT+8, 2025-12-27 05:45 , Processed in 0.103164 second(s), 18 queries .
