If I Only had $2,700 and a 100A Circuit
发表于 2021-8-31 23:24:19 | 显示全部楼层 |阅读模式
I would buy this:http://www.ebay.com/itm/Lincoln-Squa...t_12434wt_1270
Reply:What r u tigging that you have to have square wave?    And big current output?   U can get a nice ac/dc inverter tig for that kind of money.Tiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:Southpaw, I will probably end up getting an inverter, but have always liked the Lincoln Squarewaves and Miller Synchrowaves.
Reply:Maybe you don't need $2700...................... First bid is $150.00  Bet you could get it for a song.http://www.govliquidation.com/auctio...tionId=4691338MarkI haven't always been a nurse........Craftsman 12"x36" LatheEnco G-30B MillHobart Handler 175Lincoln WeldandPower 225 AC/DC G-7 CV/CCAdd a Foot Pedal to a Harbor Freight Chicago Electric 165A DC TIG PapaLion's Gate Build
Reply:I have bought a few things from DRMO  aka Govliquidation.com   be sure to go inspect it prior to bidding.   Very likely its 3 phase only...   they used to start at $50 for everything then changed to $150Tiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:Originally Posted by morgaj1Southpaw, I will probably end up getting an inverter, but have always liked the Lincoln Squarewaves and Miller Synchrowaves.
Reply:The pictures of the one in Anniston shows single phase.  But needs 110A input on 208V & 100A at 240V.MarkI haven't always been a nurse........Craftsman 12"x36" LatheEnco G-30B MillHobart Handler 175Lincoln WeldandPower 225 AC/DC G-7 CV/CCAdd a Foot Pedal to a Harbor Freight Chicago Electric 165A DC TIG PapaLion's Gate Build
Reply:Originally Posted by soutthpawDiscovered my invertec has square triangle and sinodyal waveforms...  like I would know what to do with that.   the last one i think is traditional S wave like my airco ... no idea what Triangle wave is... I know squarewave so thats 2 out of 3
Reply:Originally Posted by MarkBall2The pictures of the one in Anniston shows single phase.  But needs 110A input on 208V & 100A at 240V.
Reply:Originally Posted by papaharley03Triangle wave looks like /\/\/\/\/\/\/\/\/\/\/\/\ although the slope is often more gradual than that.You are correct about Sinusoidal wave, or sine wave. That's just like the waveform coming out of your wall socket.Although not used in welding that I know of, with music synthesis there is also sawtooth waveforms. Both up and down. /|/|/|/|/| and |\|\|\|\|\|\|\|\|\The owner's manual should give some explanation of when to use triangle waveform.
Reply:Originally Posted by soutthpawThe manuals leave a lot to be desired...  lincoln or miller.  I need to go back and review the miller tig handbook now I have a inverter...   the 2t and 4t stuff is still confusing me...
Reply:PapaHarley thanks for that link, I will read through it tmw just skimmed it tonite.  The lincoln manual did not explain that the 2t 4t does not apply with a foot pedal...  I was wo..   ndering why my torch did not have a trigger switch.. I have a switch on my water cooled torch if I decide to adapt it to work with the invertecTiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:Hey Southpaw... ran across this sentence in the product description for your machine on Lincoln's web page....triangular wave to reduce the heat input into the weld at low amperages.
GMT+8, 2025-12-27 05:37 , Processed in 0.098898 second(s), 18 queries .
