Spoolgun Question
发表于 2021-8-31 23:24:19 | 显示全部楼层 |阅读模式
I understand that TIG welding aluminum is only done in AC.  How is it that you are able to weld aluminum with a spoolgun when output is DC?
Reply:Bump.  Any ideas?
Reply:magicEd Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:helium----shhhhhhhhhhhhhh   don't tell every one.. (using donald duck voice-- breathing gas from a kids balloon) works  with argon alsoidealarc 250/250 ac-dc tigidealarc 250/250 ac-dc tig #2 used for sticklincoln sp100hh125dual arbor grinder polisher30 yrs of hand tools52 pitch blocks 6p-26prake gauge -pitch gaugeG&D prop repair 918-207-6938Hulbert,okla 74441
Reply:Originally Posted by morgaj1I understand that TIG welding aluminum is only done in AC.  How is it that you are able to weld aluminum with a spoolgun when output is DC?
Reply:Aluminum can be welded DCEN TIG.  just check out the search function.    try Spoolgun on thin aluminum.  you are using a different process CV vs CC.  also you are constantly adding filler metal to the weld with mig so it eliminates some burn through issues.  it is also not as clean of a process thus you will find few code related work that uses spool gun mig...  maybe automated mig but a hand held spool gun I doubt it.Tiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:The DCEP side of the AC sign wave, cleans the oxides off the Aluminum.  Thats why you can Mig weld Alum. with DC Reverse Polarity (DCEP).  Very simple concept.  John GaultSMAW,GMAW,FCAW,GTAW,SAW,PAC/PAW/OFCand Shielding Gases.  There all here. :
GMT+8, 2025-12-27 05:37 , Processed in 0.136120 second(s), 18 queries .
