airco dipstick 160
发表于 2021-8-31 23:24:15 | 显示全部楼层 |阅读模式
I have got an airco dipstick 160.stock #1346-6040code #0037serial # DG908028I am looking for a owners manual. Would appreciate any help.
Reply:I just aquired an Airco Dipstick 160. I've tried to find a manual online, but all the sources listed in the older posts seem to be gone also. Is there anyone on here that still has one they could email? I'd really appreciate this. Thank you
Reply:I don't have a manual, but depending on what you need it for we may be able to help you. Are you having trouble figuring out how to set up the machine for a certain welding process?Airco Ac/Dc 300 HeliwelderMillerMatic 200 (stolen)Miller Maxstar 150STLMiller AEAD200LE (welding and generating power) Hobart MIG
Reply:Originally Posted by SquirmyPugI don't have a manual, but depending on what you need it for we may be able to help you. Are you having trouble figuring out how to set up the machine for a certain welding process?
Reply:Maybe this will give you what you're looking for?http://edgewh.esabna.com/literature/..._ADI-1734F.pdfESAB Migmaster 250 Hobart Ironman 230Multimatic 215TWECO Fabricator 181i & 211iHH125EZ - nice little fluxcore only unitMaxstar 150 STH - very nice
Reply:Originally Posted by DanMaybe this will give you what you're looking for?http://edgewh.esabna.com/literature/..._ADI-1734F.pdf
Reply:I borrowed a dip stick 160 to work on my truck years ago.If I remember right you cant use flux core, no way to reverse polarity on mig.Nice welder,well built.First time I welded stick DC.Built a dc converter for my Lincoln 225 AC.If you need tips take one with you to the welding supply so they can match them.Some say that welder was built by Miller.
GMT+8, 2025-12-27 05:39 , Processed in 0.069798 second(s), 18 queries .
