Which mig wire for 4130
发表于 2021-8-31 23:24:08 | 显示全部楼层 |阅读模式
Just curious what wire should be used for chromoly (4130). I've heard that ER70S-6 shouldn't be used. I know many will say TIG is the preferred method, but I was just wondering what is recommendedfor MIG.ThanksMiller Synchrowave 180 SDLincoln PowerMig 255Hypertherm Powermax 45Torchmate 2x2Victor O/A
Reply:what are you welding that needs chromoly?tackleexperts.comwww.necessityjigs.comhttps://www.facebook.com/groups/mach...dingequipment/
Reply:70s-2 is what i would use and i would tig it.Ya gotta spend money to make money!
Reply:Originally Posted by brucerwhat are you welding that needs chromoly?
Reply:if you are getting the part heat treated(normalized or hardened) post welding use 4130 filler,if you can preheat and post heat the part you could use er80 filler.seeing as they're spindles i would suggest getting them tig welded with 4130 filler and then normalized.
Reply:70s-2 wireɹǝʌo ǝɯ lloɹ 'sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
GMT+8, 2025-12-27 05:45 , Processed in 0.104806 second(s), 18 queries .
