spoolmate 30a question
发表于 2021-8-31 23:24:03 | 显示全部楼层 |阅读模式
can i plug that machine directly into a thermadyne 10000 raider 14 pin connection, or do i need the wc24 in line?
Reply:The 30A has a 10-pin plug but the WC-24 that does have a 14-pin and is required for the 30A will plug into the Raider.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:ok, so i'm ok, got what i need , thanks duane!
GMT+8, 2025-12-27 05:45 , Processed in 0.109778 second(s), 18 queries .
