lampshade project
发表于 2021-8-31 23:23:58 | 显示全部楼层 |阅读模式
Striking rays of lights that comes from the holes of hundreds of small metal washers welded together and the lamp column molded from an actual bottle of EMPRERADOR WHISKEY illuminates magically on the bedroom walls. Attached Images
Reply:Dayum!  Our boy's an advertising copywriter publicist too!!!    Really like that one ...
Reply:Cool lamp dude. Really like your work.Brad GeorgeCurrent Equipment:AIRCO Heliwelder IV 300Amp Model - Total Awesomeness!Old 120v Hobart Handler MIGVarious grinders, cutting tools, hammers, clamps, ect..."I'm an amateur welder with lots left to learn..."
Reply:That's cool Mario. One thing, if I may. I found building lamps like that, that bringing the shade bottom down about half way down the length of the neck "works" a lot better. It balances out the base to the shade visually.If you were able to leave the bottle inside the lamp base bits and pieces, it would be cool to put a bulb inside it too. The colored glass would shine through the parts and add more shadows adn some color on the wall. Might have to scrub the base with soap and water, after welding, to get the welding soot out of the little spaces between the parts. Bottom of the bottle can be popped off with a hot wire around a cold bottle.Just a thought.200amp Air Liquide MIG, Hypertherm Plasma, Harris torches, Optrel helmet, Makita angle grinders, Pre-China Delta chop saw and belt sander, Miller leathers, shop made jigs etc, North- welders backpack.
Reply:very impressiveTotlandDesign
Reply:wait... MAGIC!?!?!?!?!?!  0.o...looks great, as usual
Reply:Originally Posted by bert the welderThat's cool Mario. One thing, if I may. I found building lamps like that, that bringing the shade bottom down about half way down the length of the neck "works" a lot better. It balances out the base to the shade visually.If you were able to leave the bottle inside the lamp base bits and pieces, it would be cool to put a bulb inside it too. The colored glass would shine through the parts and add more shadows adn some color on the wall. Might have to scrub the base with soap and water, after welding, to get the welding soot out of the little spaces between the parts. Bottom of the bottle can be popped off with a hot wire around a cold bottle.Just a thought.
Reply:....and I heard the new "Survivor" is filming in the Philippines.200amp Air Liquide MIG, Hypertherm Plasma, Harris torches, Optrel helmet, Makita angle grinders, Pre-China Delta chop saw and belt sander, Miller leathers, shop made jigs etc, North- welders backpack.
Reply:Originally Posted by bert the welder....and I heard the new "Survivor" is filming in the Philippines.
GMT+8, 2025-12-27 06:58 , Processed in 0.179114 second(s), 18 queries .
