Weld ring for 54" pipe NI 55 3/32 rod
发表于 2021-8-31 23:23:58 | 显示全部楼层 |阅读模式
We put $1000 of rod to this pipe. DIP 54" two welders 8 hours Attached Images
Reply:weld ring? do you mean a backing ring? If so do you have any Pics of the ring in the pipe .
Reply:My only question as probly alot of other peoples here is Why 3/32" rods on that size of pipe? Is that the procedure,root pass, or yall welding all the way out with them? I'm assuming thats a construction site as the welders are wearing high vis vest, No hard hats or long sleeves?Magicial Magician Of Molten Metal2006 Chevy Dually Welding Truck1975 SA-200 Lincoln Red SealMiller AEAD 200-LELincoln 225 AC/DC tombstoneVictor Contractors Flaming TomahawkProfax Tig RigMore pipe fitting tools to mentionMetabo's
Reply:we have our own welding yard. I think it was 92 that day radio was going crazy pipe forman cut the pipe to short only had the 3/32. hurry up can't wait! wheres the pipe! They think it takes an hour to weld this. they call it a weld ring here. It a backing ring when it comes from US pipe.
Reply:I can only hope those same two guys didnt weld 8 hours in short sleeve shirts, thats not good! lolMiller Pro 300 SS w/ cat Miller Bobcat 250Miller Diversion 165 Miller 211Miller Xtreme 375Miller 12vsMiller Dynasty 200 DX Miller Passport Plus w/ Spool GunMiller 30a spoolmaticLincoln AC225 Buzz Box VictorMathey Dearman - H&M
Reply:first time i heard of ductile pipe being welded..why did they do that?
Reply:Originally Posted by 74hotrodMy only question as probly alot of other peoples here is Why 3/32" rods on that size of pipe? Is that the procedure,root pass, or yall welding all the way out with them? I'm assuming thats a construction site as the welders are wearing high vis vest, No hard hats or long sleeves?
Reply:Do you use alot of the backing rings?   I have a question  do you know if there is a stamp in the inside of the ring at one of the ends that gives the size heat #  then ROB at the end ? The reason I ask is I work for one of the only Co's that make backing rings , it is always nice to see our product in use and know I had made the ring .
Reply:good luck with your skin cancer...... i never understood why people dont cover up, your not cooler if you leave your arms/hands exposed.... and YES i have a few collegues who have skin cancer on their necks for years of concentration of light there. COVER UP!
Reply:Hey, at least they are wearing their reflective vests!
Reply:I have a good tan. lots of bull frog. This is the problem with this country micro management my skin not yours! Ever heat stroke?
Reply:Originally Posted by rodabaughmI have a good tan. lots of bull frog. This is the problem with this country micro management my skin not yours! Ever heat stroke?
Reply:Originally Posted by smokin_dodgeWhile it is your skin, chances are your going to be retired when the cancer hits you, so most likely you will be on medicare so it will be our tax dollars that will be paying for you $100,000+ cancer treatment, so basically your stupidity and being a dumbass is affecting everybody. Its things like this that should disqualify you from insurance. I dont know about the rest of y'all but im tired of paying for retards who have no common sense.
Reply:Originally Posted by Pressure_Weldergood luck with your skin cancer...... i never understood why people dont cover up, your not cooler if you leave your arms/hands exposed.... and YES i have a few collegues who have skin cancer on their necks for years of concentration of light there. COVER UP!
Reply:I finished a joint, last one on the job- 115 degree boiler room. Just gloves, mask and cotton shirt, only one joint right? No biggie! Burnt both forearms raw like a lobster.Ill never burn without gear again. Heat stroke? Your from the south! ****, Im used to heat in about 3 weeks.... Ive burned on black rubber roofs in leather gear in August, on my side and back, just means more water breaks and less Camel breaks haha!Lincoln Power MIG 210 MP ( boat anchor )Lincoln Weld-Pac 100 HDHobart IronMan 230Cutmaster 42Jackson NexGenSumner Ultra ClampsDWM120
Reply:God bless the USA and all the cry babies! Get over it!
Reply:Its attitudes like this that keep me from posting on here normally.. "You're not doing it right, you're a stupid *** idiot.."
Reply:I always enjoy the irony when people criticize others for their actions they deem unsafe, then those same people fire up that Marlboro, toss back that shot of Jack, shove a Big Mac into their piehole and jump on their Harley with no helmet.Miller Thunderbolt AC/DC (Sold)Miller Dialarc 250HFMiller MM251Miller MM200 (Sold)Miller MM130Miller Spot WelderVictor O/A rigMiller Spoolmatic 1 (Sold)
Reply:Originally Posted by bratkid63I always enjoy the irony when people criticize others for their actions they deem unsafe, then those same people fire up that Marlboro, toss back that shot of Jack, shove a Big Mac into their piehole and jump on their Harley with no helmet.
GMT+8, 2025-12-27 07:16 , Processed in 0.134676 second(s), 18 queries .
