Another batch of rails
发表于 2021-8-31 23:23:56 | 显示全部楼层 |阅读模式
Almost done, they're at the powder coater's right now getting a shot of low gloss black.These are going on a bridge on the cart path of a very prestigious golf course. (I wont say the name, but the initials are G.P.I. )It's part of a larger civil project involving modifying/adding a couple of retention ponds and replacing a crumbling undersized spillway. In the years since the spillway was built there has been lots of new construction surrounding the valley this pond is in and the amount of runoff has increased.I really like the design which based on some older rails that are located near the main hotel. It had to be tweaked to meet current code, but still goes well with the older rail.I'll post more pics as soon as it's done.Original design proposal on the bottom, final revision on the top.1st of 4 10' sections tacked up. When installed they'll be connected in the field to make 2 20' sections. They're just too heavy to make up in 20' sections. Top and bottom rails 4" x 2 " x 11g tube, mid rail 2" x 1" x 11g tube, balusters 1"x 14g square tube, newels 2" x 1/4" wall square tube.I used the 1st section as a template for the next 3 sections.Time to weld 40' of rail, one inch at a time. Ugh.Last edited by app-ironworksllc; 03-22-2012 at 12:02 PM.Brian LeonardAppalachian Ironworks L.L.C.434 Long Branch Rd, Marshall, NC 28753828 649 9966828 702 [email protected]
Reply:Looks GOOD so far! You just gave me an idea for a railing that is in need of repair at my place.
Reply:Looks good Brian. I don't think a cart will "win" in a fight with those rails!PeterEquipment:2  old paws2  eyes (that don't look so good)1  bad back
Reply:Originally Posted by castweldLooks good Brian. I don't think a cart will "win" in a fight with those rails!Peter
Reply:So how do you touch up the powdercoat after the on-site welding?Nice work - Classic design!
Reply:Originally Posted by MarkNotMarcSo how do you touch up the powdercoat after the on-site welding?Nice work - Classic design!
Reply:Powder coating could be re sprayed on site and IR lamps used to flow the coatings. I've Powder Coated some great small items in my garage oven. Wife hates it, smells terrible.RonHF Dual Mig 151 w/ cap mod110 outlet and a fork ...
Reply:Originally Posted by RenronPowder coating could be re sprayed on site and IR lamps used to flow the coatings. I've Powder Coated some great small items in my garage oven. Wife hates it, smells terrible.Ron
Reply:Getting closer. Have to be at the shop Tuesday, and back to finish these Wednesday. Attached ImagesBrian LeonardAppalachian Ironworks L.L.C.434 Long Branch Rd, Marshall, NC 28753828 649 9966828 702 [email protected]
Reply:Great job bud! I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:Brain out standing work as usual your work has allways been GREAT.I have learn a iot from your post's Thank's for posting. Keep up the good work.
Reply:I need spell check can't tell my iot FROM lot's
Reply:As always you do great work Brian.How do you know the blacksmith's dog? When you hollar at him he makes a bolt for the door!
Reply:But wait there's more...Brian LeonardAppalachian Ironworks L.L.C.434 Long Branch Rd, Marshall, NC 28753828 649 9966828 702 [email protected]
Reply:Can I work for you?Nice stuff!!!.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Very nice workBacked my CATMA over your CARMA oops clusmy me  What would SATAN do ?? Miller Trailblazer 302 AirPakMiller Digital Elite  Optrel Welding HatArcair K4000Suitcase 12RC / 12 VSHypertherm PM-45Rage 3 sawRusty old Truck
Reply:Looks good. Did you use use round or square for the pickets?Common sense in an uncommon degree is what the world calls wisdom.
Reply:Beautifully done, I especially like that radius corner in the last pic of post 14.  However, I hate to admit it, but I like the way the ends of sloped stair handrails level out and return in the handicap style designs.   After I got used to them, the "un-returned" ends of the stair rails look kinda lonely and incomplete.
Reply:Originally Posted by zapsterCan I work for you?Nice stuff!!!.....zap!
Reply:Beautiful!
Reply:Man that stuff looks great!How did you anchor them into the concrete and into the bridge at the club?It all looks like it was made at the same time as the concrete was poured. Did you drill out the holes, put the rails in. Then fill them in?Precision TIG 185 and MP 210Bobcat 225NTCutmaster 42O/A tanks.... 2 Argon tanks...... 2 C25 TanksFacebook...... F2 Metal WorksETSY....... https://www.etsy.com/shop/F2MetalWorksF2MetalWorks.com....... http://www.f2metalworks.com/
Reply:Probably a round bore drill, and quickset
Reply:nice work. how thick is you table
Reply:I'm also curious about the mounting, Core Drill? and how about when you have to go into or through stone and or brick, or on brick pavers?"Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251   Syncrowave 300   30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200   1 short hood    SA250    SAM 400
Reply:Originally Posted by FexalMan that stuff looks great!How did you anchor them into the concrete and into the bridge at the club?It all looks like it was made at the same time as the concrete was poured. Did you drill out the holes, put the rails in. Then fill them in?
GMT+8, 2025-12-27 07:18 , Processed in 0.100910 second(s), 18 queries .
