Needing advise on a WC-3 with a Spoolmatic 2
发表于 2021-8-31 23:23:51 | 显示全部楼层 |阅读模式
I just bought a WC-3 with a spoolmatic 2 gun for $ 150 dollars and i cant get it to do anything. it has a 110volt (reg. house outlet) plug, positive to welder, ground and gas hookup. I was wondering if i need to have the + to welder hooked up to something to power on? Because i plug in the 110 volt plug into a outlet and it still does nothing. If anybody could give me some advise on the wc-3, i would be very thankful!! What the + to welder need to be hooked up to? What is the 110v plug in for? Does the ground have to be hooked up for it to work? I think the + to welder needs to be hooked up to a welder of some sort, which models will work? Anybody have advise?? Thanks for your time.
GMT+8, 2025-12-27 06:58 , Processed in 0.105658 second(s), 18 queries .
