Weld inspection tools
发表于 2021-8-31 23:23:47 | 显示全部楼层 |阅读模式
I found this on craigslisthttp://augusta.craigslist.org/tls/4229911340.htmlHe said it is originally over 800 dollars and wants $450. Does anyone think its worth it to have one of these. I am offering him a trade.Last edited by smilexelectric; 01-02-2014 at 10:26 AM.Miller Maxstar 200 SDPiperliner #10 Gold
Reply:If your goal is to be a CWI, yes.  If not, no.  Saw this a couple weeks prior and was considering contacting the CL seller.  $30ish per tool is solid.  That kit is $880+ now:  www.galgage.com/measuring_tool_kits.htmlGrab it!"Discovery is to see what everybody else has seen, and to think what nobody else has thought" - Albert Szent-Gyorgyi
Reply:Originally Posted by ManoKaiIf your goal is to be a CWI, yes.  If not, no.  Saw this a couple weeks prior and was considering contacting the CL seller.  $30ish per tool is solid.  That kit is $880+ now:  www.galgage.com/measuring_tool_kits.htmlGrab it!
Reply:It is a good deal. But if your not a CWI you will have no use for them until you become one.
Reply:Kinda pointless if you aren't going to be a CWI like the others have said.
Reply:Originally Posted by TSCGG13Kinda pointless if you aren't going to be a CWI like the others have said.
GMT+8, 2025-12-27 07:18 , Processed in 0.103034 second(s), 18 queries .
