18/0 stainless steel
发表于 2021-8-31 23:23:45 | 显示全部楼层 |阅读模式
I borrowed the idea of making some faucet flowers from the project forum. I picked up a couple packs of cheap spoons from wally world to use as the pedals. I don't wanna burn up alot of time trying to tig weld them to the stem so will tacking them in place with the mig running 75/25 be ok? The stem is some 1/4" solid rod I picked up from lowes. Thanks in advance.93 Bobcat 225GMillerMatic 135HF Tig 91811
Reply:You can fusion weld stainless, tacking with the TIG is the way to go, no filler necessary.
Reply:I'll have to give that a try. I wanna try an sell some of these at the local farmers market this spring so the quicker I can make them the better. Just need to secure a way of getting the spigot handles.93 Bobcat 225GMillerMatic 135HF Tig 91811
Reply:I did some SILVERWARE figures and wine bottle holders if you want to make them too. I bought my silverware at GOODWILL for 10 cents each. I tigged the silverware but may try using the mig with some .023 wire. Here's the postings if you want to look.http://weldingweb.com/vbb/showthread.php...ght=silverwarehttp://weldingweb.com/vbb/showthread.php...Oldman-dentisthttp://weldingweb.com/vbb/showthread.php...e-Holder/page2
GMT+8, 2025-12-27 07:18 , Processed in 0.099376 second(s), 18 queries .
