Settle a disagreement for me...
发表于 2021-8-31 23:23:45 | 显示全部楼层 |阅读模式
My wife and I are at a disagreement...A few years ago she had her engagement ring "welded" to her wedding ring... now every couple years she has it redipped in Rhodium  because the white gold starts to wear off... when it starts to wear, you can clearly see where the rings were welded together....To me, It looks like they were brazed with silver solder... or similarbut she swears up and down the they use GOLD to weld them together...   I didn't think gold could be used to weld ...   even if it is 2 gold pieces...   thoughts?Miller 211Hypertherm PM 451961 Lincoln Idealarc 250HTP 221  True Wisdom only comes from Pain.
Reply:I could of sworn jewelry welders (like the orion) are pulse welded and no filler. But i'm not certain at all.Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:Actually, the filler kinda looks gold....     if there is any filler at all... Miller 211Hypertherm PM 451961 Lincoln Idealarc 250HTP 221  True Wisdom only comes from Pain.
Reply:Years ago a buddy of mine said he used to tig gold, then the boss would have him tig the gold rod stub ends together.Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:I guess I was wrong....looks like there is gold filler rod.Miller 211Hypertherm PM 451961 Lincoln Idealarc 250HTP 221  True Wisdom only comes from Pain.
Reply:yes you can weld gold.  depends on the jeweler too.  some braze and call it welding and others, well, weld and call it welding.
Reply:hold off a second on soldering methods john,i thought gold both white and yellow was the same color through and through and wouldn't need redipping/coloring. the gold color on gold jewelry does not wear off.i.u.o.e. # 15queens, ny and sunny fla
Reply:Originally Posted by docwelder.,i thought gold both white and yellow was the same color through and through and wouldn't need redipping/coloring. the gold color on gold jewelry does not wear off.
Reply:Originally Posted by 7A749Wild.Never thought of that.I say buff it out & live with the color difference. My former wedding ring was white gold & never turned dull, except for wear. I took a hammer to it after I filed for divorce. Didn't look any different smashed than it did when it was round (of course, except that it wasn't round anymore) You might have to go ask a reputable jeweler for the answer to that question.
Reply:I am with the same lady, but I don't wear a ring.  for years it wasn't allowed in the trades I worked and now my fingers are so large the ring doesn't fit.  I guess I could resize it now I am not in the trades.
Reply:I have watched my jeweler size my rings with gold filler and a jewelers torch. Had no problems at all.Fireman BillHH 210 MVPMM 211 Spoolmate 100Lotas LTP5000D PlasmaOxy/Accet (Victor)Wards AC/DC buzz box30 ton old hyd pressA few brand name toolsA bunch of cheap toolsA wife to worry me and4 dogs to supervise me
Reply:My wife just had her rings re-done.  The white gold wedding band had to be re-dipped/plated since it was wearing off but I would think that her rings were brazed/soldered together since her engagement ring is platinum.  It would be interesting to know what they used as a filler.
Reply:"My wife and I are at a disagreement..."That's too bad....One think I have learned after 40++++ years marriage is .....  YOU ARE WRONG,  SHE IS RIGHT..  live with it.The only way you can get the last word in this argument is is the classic  "yes dear"Good luck
Reply:I know its hard to believe but some women are allergic to gold and need the rhodium plating to prevent a rash.miller thunderbolt 250vlincoln square wave tig 175 prolincoln idealarc mig sp250everlast tig 210EXTeverlast power plasma 50chicago electric (hf) 130 tig/90 arcchicago electric 90 amp flux wire3 sets oxy/acet
Reply:Originally Posted by boatbuoyI know its hard to believe but some women are allergic to gold and need the rhodium plating to prevent a rash.
Reply:So gold can be tig welded? My wife has been bugging me for a while now for the wedding ring half of her ring. I wear Ti.
Reply:Originally Posted by 7A749I took a hammer to it after I filed for divorce. Didn't look any different smashed than it did when it was round (of course, except that it wasn't round anymore)
Reply:Oh you poor guys. When will you learn. I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:Your first sentence says it all..Impossible to settle, your arguing with a woman.tackleexperts.comwww.necessityjigs.comhttps://www.facebook.com/groups/mach...dingequipment/
Reply:Originally Posted by weldermikeOh you poor guys. When will you learn.
GMT+8, 2025-12-27 07:19 , Processed in 0.072659 second(s), 18 queries .
