rfc23g part needed
发表于 2021-8-31 23:23:44 | 显示全部楼层 |阅读模式
i'm looking for two things, a switch,part number 011 628 and a reostat that is about 25 ohms 300 watt for my old 44d weling machine..any one with those parts?
Reply:http://miller4less.com/advanced_sear...=15&search.y=8http://miller4less.com/advanced_sear...12&search.y=10I don't have a switch and I'll have to see what the last resistor is that I have but something tells me it's not the one you need.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:thanks duane!
Reply:Turns out I do have the 004652, 25ohm/300w resistor but I just looked up the 44D unit and you would need the 34ohm/300w unit which I don't have.http://miller4less.com/advanced_sear...17&search.y=11MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Mike,As I stated in my PM to you, I don't know what I was thinking because you are correct in that you need the 25ohm/300w resistor for the RFC-3GD25A or RFC-23GD25A that would be required for and match the 4-prong remote plug on your 44D.To add insult to injury, the link I posted above is for the 34ohm/300w panel rheostat and not a foot control. My apologies for causing any confusion. Last edited by duaneb55; 01-06-2014 at 12:02 AM.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
GMT+8, 2025-12-27 07:18 , Processed in 0.096495 second(s), 18 queries .
