Cutting torch roller guide
发表于 2021-8-31 23:23:37 | 显示全部楼层 |阅读模式
I swear I remember seeing a couple of threads here in the past with torch guides that someone had built, but I cannot find them anywhere. So I made one today out of some scrap I had laying around, but I spent alot more time figuring out how I wanted to build it than actually doing it...Hopefully after tomorrows cookout I will have time to try it out! I am still deciding on what to do with the other end, cut it off, bend it down... any suggestions?
Reply:Originally Posted by BACI swear I remember seeing a couple of threads here in the past with torch guides that someone had built, but I cannot find them anywhere. So I made one today out of some scrap I had laying around, but I spent alot more time figuring out how I wanted to build it than actually doing it...Hopefully after tomorrows cookout I will have time to try it out! I am still deciding on what to do with the other end, cut it off, bend it down... any suggestions?
Reply:You should put a pair of wheels on the side, running horizontal, so you can use a piece of angle or tubing as a straight edge. I sure need a straight edge  What size tip and what pressure settings? I haven't found much on pressure settings for Harris torches running LPG.Bruce
Reply:Originally Posted by weldbeadvery nice..i thought the intent was to hold it with the same hand that held the torch, like it shows in the pic..fingers on the torch handle and the roller handle, thumb on the cutting ox...
GMT+8, 2025-12-27 07:30 , Processed in 0.085041 second(s), 18 queries .
